I have a looped system, with 2 points of connection to an existing water main that are modeled as reservoirs. Each reservoir has a GPV.
When I run the model I receive an error (Message ID 40005) and flow is showing through the reservoir at 500gpm even though there is no demand proposed for any of the junctions.
I don't receive this error when I only have 1 reservoir.
Why is the network considered "unbalanced" when there are 2 reservoirs?
Hello Jaclyn, Try increasing the number of trials in the calculation options. To do this, open the calculation options from the Analysis menu. Double-click the active calculation option to view the properties. Find the Trials property and increase the value. For instance, if this is set to 40, change it too 100. Sometimes a few more trials are needed for some models. If that doesn't help, check the properties of the GPV. Make sure the curve is accurate and make sure that the orientation is correct (basically that the correct pipe is the downstream pipe). The following link has other steps that you can try as well: communities.bentley.com/.../8769.troubleshooting-network-unbalanced-or-cannot-solve-network-hydraulic-equations. If none of this helps, we will need to see a copy of the model files. The following link has information on sending the model to us: communities.bentley.com/.../32255.sharing-hydraulic-model-files-on-the-haestad-forum. If you upload the model to Sharefile, please post here with the name of the file so that we know it is available. Regards, Scott
Jaclyn, You have uploaded the .wtg file and the .wtg.dwh file. In order to view your model file we also need the .wtg.sqlite file. Once that is uploaded please post a reply.
Mark
Jaclyn,
Do you have more information about the connections to the existing systems? This wiki explains how to model a connection to an existing system . One of the assumptions when modeling connections to existing systems is there should not be more than one modelled at a time. Having more than one can skew the results.
The way the model is currently setup the network is being solved as the difference between the hydraulic grade at R2 - R1 (288.48 ft. - 287.86 ft. ) - the headlosses from the GPV's and friction losses from the pipes.
What amount of flow are you expecting out of each reservoir?
