Is it possible to export Calculation options(Transient solver) as .html in Hammer.
TR.
Sushma Choure
Bentley Technical Suppport
If you're interested in using the same calculation options in multiple models, I would recommend using Seed files. Basically you would set up the calculation options the way you'd like, plus other things like units, libraries/catalogs, color coding, annotations, etc, then save as a Seed file. When you want to start a new project, you would "open from seed" , essentially starting from a template. More on that here:
Save Time using Engineering Libraries, Shared Flextables and Seed Files
