Dears:
how i can model Surge vessel failure in bently hammer.
thanks
Sawsan Bataineh
Project Manager
Surge vessel" could refer to either the surge tank node element which is open to the atmosphere, or the hydropneumatic tank element which uses pressurized gas to attain a hydraulic grade much higher than the physical top of the tank. You can read a lot more about the latter in this article:
Modeling Reference - Hydropneumatic Tanks
If by "surge vessel failure" you mean that you need to simulate what happens if something breaks in the tank, then you'll need to consider exactly what will physical happen and think about the hydraulic impact. As with your other post, I would suggest checking with whomever made the requirement for clarification. The requirement may be to check what happens if the tank is essentially not functioning at all, which would mean setting up a scenario in HAMMER with the surge tank inactive (is active = false) or a valve next to it fixed in the closed position.
