How to simulate the transient event in a foul water pumping station if there is a duty/assist arrangement with 2 pumps ? How can i set the pump start/ stop levels as well as how to set up the pump curve? Does the software calculate the combination curve?
Hello Thanasis,
Before performing the transient analysis in Hammer, you should perform the hydraulic analysis of the model using either WaterCAD or WaterGEMS.
The initial conditions like pump modeling, tank modeming should be done first in WaterCAD/GEMS before performing the transient analysis.
The pump combination curve option is available in WaterCAD, WaterGEMS and SewerCAD but not in Hammer.
Here is technote including detailed information about Pump combination curve.
You can enter the pump curves by going to Components>Pump definitions and pump start stop levels can be configured with the help of the controls.
Please see below link to know more about how to set up the controls in model.
http://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/2567.creating-controls-conditions-actions-and-control-sets-tn
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Jesse Dringoli
HAMMER uses the same exact solver as WaterCAD and WaterGEMS for the initial conditions (steady state or EPS). The provides the starting conditions for the transient simulation.
I see that you mentioned a "combination curve" - if you're referring to modeling a single pump node to represent more than one pump, I would advise against doing this in HAMMER. Although you might have accurate initial conditions, the transient response may be skewed. For a transient simulation, it is important to model things as they are, since modeling artifacts and shortcuts could potentially significantly effect how the transients interact in the network.
The Combination pump curve tool in WaterCAD and WaterGEMS allows for multiple pump curves, efficiency curves, wire-to-water efficiency curves(overall efficiency curve), and system head curves to all be displayed on a single graph. More on that tool here:
Pump Station and Pump Combination Curves
