Ref: http://communities.bentley.com/products/hydraulics___hydrology/f/5925/t/93998.aspx
I have one question about sewerGems V8
I want match pipes at crowns.i am follow this way: components > default design constraints > node Tab >pipe matching set to crowns
but in profile shown pipe invert match together
It is possible that some other, higher priority design constraint will be violated if the crown matching is implemented. You can find more information on the design priorities in the Help documentation.
If that doesn't help, I will likely need to see the model in order to better look into this. Please use the instructions below to provide the model.
There are two options for sharing your model files on BE Communities. If you would like the files to be visible to other members, you can upload them as an attachment using the ‘Advanced Reply editor’ before posting. If your data is confidential, you can follow the instructions in the link below to send it to us via Bentley Sharefile. Files uploaded to Sharefile can only be viewed by Bentley.
communities.bentley.com/.../bentleysecurefilesupload.aspx
Please reply to the forum when the file is uploaded. That way I will know when it is available.
Thank you.
Scott Kampa
Bentley Technical Support
