HiI have been installing and uninstalling WaterCAD V8i (select series 4) 8.11.01.58 for 32bit systems all day on Windows 8.1 Probut each time I Start a (New Project) the program crashes and I get an error.I have tested the program on Windows XP and It Worked Perfectly fine.and i tried every possible means of Windows compatibility which ended with no good.Is there any method or installation that would work on windows 8.1 ??Thanks in advance
Hello Maen ,
WaterCAD SS4 08.11.04.58 is not certified to work on Windows 8.1 operating system that means it’s not yet compatible with Win 8.1. Our upcoming version would be compatible with windows 8.1 OS, which will be releasing soon.
Whether as WaterCAD SS4 is compatible with Windows XP, Windows Vista, Windows Server 2008, Windows Vista x64, Windows Server 2008 x64, Windows 7, Windows 7 x64, Windows 8, Windows 8 x64, Windows Server 2012 x64.
Sushma.
Sushma Choure
Bentley Technical Suppport
Although 8.1 isn't fully certified yet, it's similar to 8. Could you provide us with some additional details about the error? For example a screenshot or copy/paste of the message.
Just after selecting New Project the system crashesand this is how the main screen looks if you dismiss the dialog windows
Thanks for posting the screenshots. Please click the button in the very bottom-left corner of the error window: "Click here to see the details..." and post what you see.
Thank youI have Uploaded the log file that pops
