Hello
In ‘Calculation Options’ when ‘calculation type’ is changed to ‘age’, the option ‘Type Analysis Type’ disappears. Why does it do?
Sim
Hello Sim,
Water quality analysis can only be performed for extended period simulations, so you won’t find the option of time analysis type while performing the age analysis.
Before changing the calculation option to age analysis make sure you have set the time analysis type as EPS.
Hope this helps.
Sushma Choure
Bentley Technical Support.
Bentley Technical Suppport
Answer Verified By: simbaa
Sim,
As Sushma mentioned Age analysis is performed for Extended Period Simulation (EPS).
Whenever an option related to "duration" is selection under Calculation Type the software will automatically run for certain duration as provided. So for Age, Constituent, Trace, [and Multi Species Analysis], it will always be an EPS run.
HTH
