Hello
1- What is difference between ‘first order’ and ‘zero order’ in ‘wall reaction rate’?
2- In ‘Analyzing Constituent Concentrations’ (help document in WaterGEMS v8i) it does not explain steps completely and just says to do this after that very briefly. How can I get some explaination about? For example about bulk reaction rate, wall reaction rate or diffusivity and their complex UNITs?
3- According the ‘Help document’ for ‘Analyzing Constituent Concentrations’ why we add concentrations for Junctions, pipes, Tank,Reservoir, Pumps and Valves? From which it injects and why we add concentration to anothers?
Sim
Zero Order: "A Zero-order reaction has a rate that is independent of the concentration of the reactant(s). Increasing the concentration of the reacting species will not speed up the rate of the reaction i.e. the amount of substance reacted is proportional to the time." The reaction rate is constant such as,
r = k
Example: Aging is of zero order rate. You are older one day, everyday.
First Order: "A first-order reaction depends on the concentration of only one reactant. Other reactants can be present, but each will be zero-order." The reaction rate can be represented by:r = k * concentration.
So, no matter what reaction rate you are interested in, the fundamental is the same. "Wall decay coefficients, however, are more difficult to measure and are frequently estimated using disinfectant concentration field measurements and water quality simulation results." - Advanced Water Distribution Modeling and Management BookReferences:http://en.wikipedia.org/wiki/Rate_equationhttp://en.wikipedia.org/wiki/Order_of_reactionhttp://chemwiki.ucdavis.edu/Physical_Chemistry/Kinetics/Reaction_Rates/Zero-Order_Reactionshttp://chemwiki.ucdavis.edu/Physical_Chemistry/Kinetics/Reaction_Rates/First-Order_Reactions
Answer Verified By: Scott Kampa
Q: How can get more information about Water Quality Modeling?
I encourage not to limit within the Help document for this broad and hot topic. External references might be the best to educate and stay up to date.
Some references:AWDM book: http://www.bentley.com/en-US/Training/Products/Resources/Books/AWDM.htmModeling Water Quality, ISBN: 13: 9781583218167Field Studies (EPA): http://nepis.epa.gov/Adobe/PDF/2000D2C2.pdf
Sim,
For the third question, I assume you are referring to Initial concentration that's been added to the nodal elements? This is done under assumption that there will be some level of constituent concentration right at the beginning of the simulation. At any given time, there will be some constituents in the distribution system and to model that we add the initial concentration.
If you are not referring to this then please add some details. Thank you.
Hello Akshaya,
1- Do you mean that 'initial concentration' is the concentration (of e.g. Chlorine) at the zero time ( I mean the time of running the network)? Who defines these initial concentrations? From where it injects?
2- please explain a little more about UNITs of 'wall reaction (m/day)' , 'bulk reaction ((mg/l)^ (1-n)/day)' and diffusivity (m2/s).
Hi Sim,
Yes, Initial Concentration = Concentration at the time zero = simulation start time.
The value that goes into the nodal points are generally some guesses, doesn't have to be exact. This is because, water quality scenarios are typically of a long duration so that the system could reach equilibrium (meaning, the pattern of the graph is nearly parallel to time axis, x-axis). You can simply enter some meaningful value and let the model run for a longer duration.
Regarding the Units, I encourage to understand the equations behind them and for that please look at some of the books I mentioned earlier in the thread. This help link will also show you some of the equation.http://docs.bentley.com/en/HMWaterCAD/Bentley_WaterGEMS_Help-19-32.htmlThanks,
