Hello
I'm using sewergems select series 3 to model a sewerage network
after i have built the model and entered the load i have run the design and it went crazy and gave me wrong direction of the flow
the flow goes out of outfall not toward outfall and this is my first time to see it in sewercad
them model is attached
thanks
Hello Ahmed,
I just ran your model in SewerGEMS SS3 (08.11.03.84) and all the flows went towards the outfall. Is this the same build you are using, and do you have the latest cumulative patch applied? Below is a screen shot of the model.
Terry FosterTechnical SupportHydraulics and Hydrology product lineBentley Systems, Inc.
Answer Verified By: ahmed hassan
Hellomy friend
I have sewergems ss3 in my office
v (08.11.03.77)
how could i get this comulative patch ?
and should this make problem to run the network?
regards
I would suggest you upgrade to build 08.11.03.84 and apply the latest cumulative patch for this build.
Here is a link to a support solution that explains how to download and install the software:
communities.bentley.com/.../8175.aspx
