StormCAD SS3 projects created outside of ProjectWise
If a StormCAD SS3 project is saved directly into ProjectWise, it automatically creates the .stsw as a master file and the other associated files (.dxf, .dwh, .mdb) as references. If those same files are dragged & dropped into ProjectWise, no such relationship is established. Is there any way to establish the relationship after the fact, like by using Scan References or is saving it direclty from StormCAD into ProjectWise the only way that relationship is established? Same question goes for CivilStorm SS3.
