My model includes Scenarios for 2, 10 & 100 yr. reoccurrence intervals, utilizing the Modified Rational Method. Rational Method calculations in Virginia (and probably many other locals) require the use of a Cf (saturation coefficient) multiplier for reoccurrence intervals above the 10 yr. (Cf25 = 1.10, Cf50=1.20, and Cf100=1.25). So for those large storms beyond the 10 yr., the Rational Method Equation becomes Q = CfCiA.
Is there a way to account for this multiplier in the program calculations for the selected reoccurrence intervals (25, 50 & 100 yr.) as needed?
Any help would be greatly appreciated.
Tom
Hello Tom,
Yes, you can use the "C Adjustment" option in the modified rational catchment properties to apply your adjustment factor. Make sure to set up each return event's scenario with a different Hydrology alternative, to keep the settings separate. See below support solution for more information:
communities.bentley.com/.../15965.applying-a-c-adjustment-factor-to-different-return-events.aspx
Let us know if this helps.
