SewerGems models with dxf background not opening
SewerGems V8i files with dxf background is not opening in my system. However, when I copied the .stsw and database files to a different location (without the background) and opened it worked. Also, when I am trying to add a dxf background file to a new model, the software is crashing. The screen shots are attached herewith.
