For investigation purposes TSG asked me to set MS_LMDEBUGLOGLEVEL in the system properties to ALL.
How do I set them to lower levels back again? What options do I have?
Can I do this without having to restart any services, and will the change of this var. work immediatly?
Thanks for a quick anser.
When setting MS_LMDEBUGLOGLEVEL=ALL, you have probably set MS_LMDEBUGLOGFILE to some file path and name.
To stop the log operation just remove the two variable.
To remove the two variable just follow the instructions already recieved, once you see the list of variables, simply select one, and click remove, same for the second variable.
