Tools > Run products in non-production mode
Opens a dialog in which you can select the products that you want to run in non-production mode.
For what is this option under License Management?
Some products can be configured to run in a non-production mode- to be used in disaster recovery, failsafe mode, evaluation mode, etc. In order to use software in a non-production mode, the request must go through an account manager and the software must be set up on the contract as non-production and then be activated with the "Run in non-production mode" in the License Management Tool.
Answer Verified By: Oto
