password protecting drawnings - [Archived] MicroStation V8 XM Edition Forum - MicroStation - Be Communities by Bentley
MicroStation
MicroStation
This is the “general” community for all issues that are not associated with any of the “peer MicroStation communities”.
  • All,
    I am using microstation xm ver 08.09.04.51 and would like to password protect the drawing but still have it so you can reference the drawing without having to use the password to attach it. I have several people here that only need to reference the drawing and do not need to have permission to change anything in the drawning. I know I can protect it but when I go to reference the drawing into a new one it ask me for the password. Is there a work around?
    Thanks David
  • Have you tried adding access for everyone with only Print and possibly Export Rights (View is the default)? You may still be prompted for a password, but pressing Enter should be good enough to attach it as a reference.
  • Adding to this, if you protect the file using a digital certificate and then create limite access for everyone, then other users will not be prompted for a password.
  • How the URL protection works under digital rights? It's unclear from documentation
  • The URL field in the License Properties dialog specifies a URL that must be accessible in order for the rights to be granted. This allows you to control the lifetime of a file protection license remotely.
    For example, suppose you protect a file called BID.DGN and you create an Everyone license in this file with the specified URL:
      http://www.mycompany.com/bidisvalid
    Then you send the protected BID.DGN to a contractor. When the contractor tries to open his copy of BID.DGN, his MicroStation will first check if he can access http://www.mycompany.com/bidisvalid. If so, it opens the file. If not, it refuses. You can therefore cancel the contractor's right to access his copy of BID.DGN by removing the "bidisvalid" document from your website.
    Note that the URL must include the scheme. Currently, only "http://" and "https://" are supported.
    I should mention that a determined user could circumvent the URL check. A user could also circumvent the expiry date check. Checks like these are intended to communicate your wishes to people that you trust. They are not meant to control the behavior of adversaries or "bad guys." The only way to keep a bad guy from misusing your data is to deny him access to it. The only sure way deny access to a protected file is to create a license based on a strong password or, better yet, a digital certificate. That way, only the intended recipient will be able to open the protected file in the first place.
