Object Snap - [Archived] MicroStation V8i Forum - MicroStation - Bentley Communities
Object Snap
MicroStation
MicroStation
This is the “general” community for all issues that are not associated with any of the “peer MicroStation communities”.
Object Snap
  • Working on a 3D V8i dgn File, when i snap to end of the top line line.
    my new location is not top of line but the bottom of line. if start new line or circle it starts from the bottom of the line i'm snapping to.
  • To clarify what you are trying to describe, could you provide a simple test case that could be looked at? TIA
  • Sounds like the ACS Plane Snap is enabled - to disable click on the lock and the bottom of your screen.
