Im new on the forum. Just transitioning from AutoCad to Microstation and have this problem:
When I want to rotate the element (Not view) along a plane, Autocad offers 3D rotate option. Where one enter 3D rotate on command line, asks for element of interest-select and entre, then asks for the plane-select 2 points along plane line,
Select angle+ or - 90 for instance. This kind of rotation does not rotate elements clockwise or anticlockwise but rotates elements in the Z so that they appear as a single line unless you change view to isometric thats when one sees the elements upright like a section.
I cannot do this in Microstation V8i. Is there a way out?
