How to place element on default Z elevation - z_[Archived] MicroStation V8i Forum - MicroStation - Bentley Communities
Untill MicroStation SS2, when placing dimension element on z=0 on Top View, Set [ACS Lock=on] and [ACS Plane Lock=on]. then place dimension element by snaping the point of a element which is placed on Z=1000, the result is the dimension element is always placed on z=0.
But On MicroStation SS3 08.11.09.357, doing the same opertion, the dimension element will not be placed on z=0, it will be placed on the first snap point same height. Sticky Z lock=ON/OFF have the same result. how to let SS3 work the same like SS2? Any idea would be welcome. thank you.
I use Key-in: SHOW DEPTH ACTIVE. it showed my view active depth=0.2888
3 Replies (Most Recent Reply)
^ Go to first post
