line style scale - MicroStation - Forum - MicroStation - Be Communities by Bentley
line style scale
MicroStation
MicroStation
This is the “general” community for all issues that are not associated with any of the “peer MicroStation communities”.
line style scale
  • How can I change an existing line style scale (the lengths of dashes, and dots in a line style)? As an Autodesk user, I know this can be done by changing the drawing scale, or an elements linetype scale. Not sure how to do this in Microstation. The issues is I have a drawing someone else did, but the line styles do not have the appropriate scale (lengths between dashes, and dots). In the help file under Line styles > scale it talks about scales for cell placement. The line styles are not cells, so I'm not sure how to obtain the desired result.
    Microstation v08.05.02.70
    Geopak v08.08.03.24
    Vista 64-bit
    8 GB ram
    Duo Core 2.8GHz
    Dell Precision M6300
  • Select the line(s) you want to change. Key-in: change linestyle scale 1
    This is assuming you want the scale to be 1, you can enter any number you want/need.
    --Kevin
  • thank you. that is what i needed.
