The MicroStation product team is pleased to announce the availability of MicroStation CONNECT Edition x64 Update 2 (10.02.00.39) on Fulfillment Center and for update through the CONNECTION Client. This version of MicroStation CONNECT Edition incorporates a number of new capabilities as well as user requested fixes. Please refer to the "What's New Highlights" section below for some of the major product updates and enhancements.
If you have MicroStation CONNECT Edition or MicroStation CONNECT Edition Update 1 already installed on your machine, you can download and install MicroStation CONNECT Edition Update 2 from the CONNECTION Client. MicroStation CONNECT Edition Update 2 will replace MicroStation CONNECT Edition and MicroStation CONNECT Edition Update 1 to MicroStation CONNECT Edition Update 2. Sign into the CONNECTION Client to view and apply your Application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
If you would like the full installation of MicroStation CONNECT Edition x64 (Full) Update 2, please follow these steps to download it from Fulfillment Center:
Important installation requirements and notices are found in the Readme.
http://communities.bentley.com/products/microstation/m/microstation_gallery/272100
MicroStation has a new, multi-threaded visible edge processing engine, which will take advantage of all CPUs and cores of a machine by parallelizing its calculations. This will significantly improve the performance of all operations that involve visible edge processing, such as exporting and merging Visible Edges, calculating references' Cached Visible Edges, and Non-rasterized Printing.
For the full list of What's New and Changed please refer to the Help section within MicroStation CONNECT Edition Update 2. Please refer to the following link for the Resolved Issues in MicroStation CONNECT Edition Update 2
http://communities.bentley.com/products/microstation/m/microstation_gallery/272107
Also, be sure to visit MicroStation forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
