Convert to AutoCAD color table - FileFormats - Forum - FileFormats - Be Communities by Bentley
FileFormats
FileFormats
This is the community for things related to Bentley product interoperability with file formats other than DGN.
FileFormats - Forum
This question is answered
When saving to DWG MicroStation does a closest match converting MicroStation colors to the fixed AutoCAD color table. Is there a way to attach the AutoCAD color table in MicroStation and have color numbers reassigned to closest match. This would avoid having to round trip to autocad and back. Thanks, DavidG
Verified Answer
  • So you are looking for a utility that maps the RGB value of an element to a new color table index.  It does not have to be ACAD color table, any color table.  I don't believe that MicroStation currently has this tool but I won't be surprised if someone out there may have a VBA or MDL program that does similar remapping.
All Replies
  • There is a delivered AutoCAD color table you can use.  From menu Settings->Color Table->File->Open, by default you should be seeing color tables available under \Workspace\system\data\.  Open acadcolor.tbl to use this table.
  • Don,  yes I'm aware of the table, which I would like to use.  But attaching the table will not  reassign  color numbers to the elements.  Saving to dwg does a good job of reassigning color numbers to the appropriate acad color.  What I would like is to reassign color numbers to closest dwg color match without having to save to dwg then save back to dgn.
    Davidg
  • Don,  Yes it could be any colortable.  Obviously the coding for ACAD has already been done.  Ideally if you attached the ACAD table (or any table)  it would prompt if you want to assign the element color # to the new equivalent.  Also on this wish list would be if you are using the ACAD table  or are in DWG mode that the color picker use the ACAD layout rather than the 16x16 grid.
    Thanks DavidG
