Printing CIT images to a pdf using print organizer - Printing and Plotting Forum - Printing and Plotting - Bentley Communities
I've been having issues printing a CIT image while using print organizer.  I'm using MicroStation V8i SS3 (version 08.11.09.357).  When I try to print a pdf using print organizer, my CIT image will not print.  I have looked into making sure that it's on a level that will print along with making sure the print raster images is selected in the print organizer settings.  Attached are the files that I used.  Any ideas on why this CIT image won't print?  Is there a limitation on image size while printing with print organizer?
Print-PDF-Testing.zip
  • In reply to Dustin Hunt:
    Hi Dustin,
    Thanks for the extra configuration files.
    I have found that if I check the ``Print monochrome raster as-is```option I can reproduce your problem with your test.pset. Otherwise when unchecked the .CIT is printed correctly even with test.pset and your ptlcfg file.
    I`m not sure why it is so, but could you check if the ``Print monochrome raster as-is```option is checked by default in your Title-CIT-Test Properties dialog?
    Mathieu
      Answer Verified By: Dustin Hunt
^ Go to first post
