You can now register for the 8th MicroStation SIG event: A-Z Printing and Plotting!
Register for MicroStation SIG: A-Z Printing and Plotting!
Online Event: MicroStation SIG: A-Z Printing and Plotting
Live Q&A Webinar: Tuesday, March 11th at 8:00 AM PST or 3:00 PM PST
Cost: None! Must register to receive video links and connection info. Register here!
Description: There are several free on-demand courses on printing and plotting. This special interest group web meeting will bring those together in one location using the “flipped classroom” approach. To get maximum benefit from this Special Interest Group meeting, registrants will be sent links to the learning sites ahead of time. Questions can then be posted on Be Communities. The webinar itself will go over what are considered the basics, and then will answer any questions that have been posted or asked during the webinar.
What We Think about the MicroStation SIG events: This is an innovative way to learn MicroStation using the “flipped classroom” method. Similar to our in-person Bentley Bash event, you have the opportunity to work through the exercises, as well as have an expert there to answer your questions. Unlike the Bash, the online “flipped classroom” model allows you to go through the exercises at your own pace and repeat if necessary. Through the Live Q&A Webinar you have the chance to ask the experts any other questions you may have. You will learn a bunch at no cost or travel!
Here are some questions that have been sent to us directly...
1. what is the most common workflow for printing, scale border up or scale referenced work down?
2. are pdf's available for on demand, hands-on courses?
3. give simple example of pen tables and design script.
4. pls go over print organizer
We will answer those for sure. Please submit any other questions on printing....
Tom Lazear
1. The .pdf, .tiff, and .cit attachments sometimes print with gray background even though transparency is on, is there a fix for this problem?
2. When we print to a small printer it wants to print from bypass tray, is there a way to select other trays? How is this done?
1) If using the windows driver to print to paper you must have the rasterized button checked on via the print dialogue to get transparency
2) You can edit the printer.pltcfg under windows printer section and select the tray. Here is info from the help file:
Specifies the default paper tray to be selected. This value can be any valid tray name for the selected printer, such as
Tray 1, Manual Feeder, and so on.
When a printer has a choice of trays (or paper sources) you can check the available tray names by clicking the Configure Windows Printer icon in the Print dialog, which opens the system Print dialog. In this dialog, you can select a printer and then view the printer's properties, including that for paper source.
Questions raised during Live Q&A Webinar for MicroStation SIG #8: A-Z Printing & Plotting
