Getting Started Common Acronyms FAQ Forum Help Forum Tips FTP Site Helpful GuidelinesInserting and Attaching images, videos, or files to postsProduct Community Directory SELECTsupport
Are you using AccuDraw? The AccuDraw RE shortcut will be helpful in orienting the compass to align with your profile so that it will be easier to define the axis for the helix in the plane of the profile. The helix feature always maintains your profile orientation during the sweep (it works similar to the Helical Surface tool) which means you do need to draw/place the profile in the correct orientation. Solid by Extrusion Along works similar to the Tube Feature, where you can select both path and profile. Currently the Tube Feature lacks an option to lock the profile rotation, that would be a nice addition.
-B
