Getting Started Common Acronyms FAQ Forum Help Forum Tips Secure File Upload Helpful GuidelinesInserting and Attaching images, videos, or files to postsProduct Community Directory SELECTsupport
Further to what Budlite says...if you're using custom line styles, the following article may have some suggestions for you on how to control/modify the scale: communities.bentley.com/.../all-about-custom-line-style-scales.aspx
Best Regards,
~Inga
Pick the tool. Adjust the settings. Follow the prompts.
If you're talking line codes 1-7 that come with Microstation, you can't. They aren't really linestyles. If you're looking at actual linestyles, it should be WYSIWYG unless you resymbolize the plot.
If I am preparing a drawing for plotting at 100 scale. How do I set up my linetypes to look correct on the screen and at the plotter?
Sean Logal
