HELLO, I'm working with contextcapture, finally I produce a model, and I can see it with Acute 3d viewer, but
I want to place the model inside microstation, Is this possible?
thank you
Keith Raymond
Hi genis,
as Keith wrote, it's possible. But it's important to mention it's possible in MicroStation CONNECT Edition only, not in previous versions.
You have two options:
For more information, check Acute3D Files Support chapter in Home > Setting Up the Environment > Using DWG and Other File Formats > Exchanging Data Using Other File Formats in MicroStation help.
With regards,
Jan
