I have started to use some of the point cloud tools in the SS2 release. I have not found a way to be able to render a frame or animation of the point cloud. Is this even possible and what settings/render style should I use?
You should be using wireframe or smooth for this and not Luxology. We might try and get this to work at some point but for now Luxology will not render these points.
JF
Kind of an old thread, but I wanted to bring this to your attention (you're probably already aware of it, though):
labs.autodesk.com/.../3dsmax_pointcloud
Point clouds collected by terrestrial laser scanners could provide engineers & architects with complete, finely detailed 3D 'models' of the existing condition of thier project site - and if the visual quality is acceptable, this could save a significant amount of time that is currently spent modeling the existing condition with surfaces, cells, solids, etc.
I'd very much like to have the ability to use point clouds in MicroStation's Luxology render mode.
Adam,
Support for point clouds in Luxology will be in SS3.
Matt
Sweet! I feel like hi-fiving someone right now.
Jerry, is this function to render pointclouds with the photo's from where the point clouds are taken able to render in the Beta 08.11.09.209.
CP
