Hi, anybody can tell me if the openplant project administrator is a separate installation or incorporated with some other application, I do not find it after the installtion of openplant modeler.
thanks a lot
Hi Tony,
OpenPlant Project Administrator is separate application and hence you need to install it separately. However, workspaces of OpenPlant Modeler, OpenPlant PID and OpenPlant Support Engineering are integrated with it.
You can refer below link to FAQs:
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/18535.openplant-project-administrator-faq
Regards,Harpreet
Did you try latest OpenPlant Modeler SS6 version? It comes with Structural Module (SMC). Please see below link for What's new with OpenPlant Modeler SS6.
http://communities.bentley.com/products/plant/design___engineering/m/openplant_powerpid-files/271780
Hope this helps!
