Getting Started Common Acronyms FAQ Forum Help Forum Tips FTP Site Helpful GuidelinesInserting and Attaching images, videos, or files to postsProduct Community Directory SELECTsupport
Scott,
I have a workaround solution for that.
I opened the V7 files with Bentley view and then plotted them.
Then i managed to do the design compare with V7 files.
So if you open V7 files with bentley view 8 or microststion8 and then do the plotting the problem was solved.
Hi, Are you using design compare with ProjectWise Web server or without it? Can you provide us more details? What other products are you using? Please provide us exact versions. What OS are you using?
Regards, Dalia
We have Interplot server V8i installed.
When we try to plot dgn files using Microstation V7 and design compare them we get the following error.
Design Compare Error: DprDiffLib Error: The file "E:\DigitalPlotting\DPRQueryResults\tmp\778826828\DIF5D.tmp" has no differencing metadata or the server ran out of disk space while writing the input file. You can not compare DPR files generated without metadata, DPR files generated via APLOT, DPR files created with the InterPlot MDL Printer Driver, or DWG/Raster/"Old DPR" files in an IPS file.
When we plotted the same files using Microstation V8 ,the design comparision worked successfully.
Can any one help me out of this????
Paresh.Bhoir
