Dear all,
I request your help regarding the import in BRT of geometric data gathered in a report sheet (available in PDF and converted in TXT file).
I have not access to the XML/ALG file of this horizontal alignment and this report is the only alignment data available. This horizontal alignment data comes from (or is very close to) a basic XML Report proposed by default in BRT (using the abbreviations available in civil.xin). I tried to import this report through the Text Import Wizard using On Alignment Point, Off Alignment Point, Station, Radius, N and E… but despite few tries, I didn’t find the way to obtain the desire outcome : practically after some modifications of the .txt file, my “best” result in BRT is a combination of only linear elements.
You will find the TXT files attached. I hope you could show me how import these data created in BRT back into BRT.
Thanks in advance,
See attached file..
Html file attached..
Thanks for your reply, but could you explain/detail how you did that?
Thanks in advance for your feedback
It's not complicate..
I created an excel file (attached) to convert txt format to ASCII format. than I used the macro (Tools -> Run Macro -> AlignmentFromASCII)
Thanks a lot for your answers and your macro. It works well and from now I will use more often the ascii format.
Thanks again!
