Hi all
I am having trouble placing a vertical crossover between 2 lines both of which are inclined.
I have a 2 line railway (an up and a dn).I have used a series of curves and transitions to design the dn main, and I have paralleled the dn geometry to the up using an offset of 3.405m.
I used 3.405m between the two centre lines because I wanted a standard 6ft of 1970 and the gauge was 1435 (inclined) hence why 3.405m was used.
The issue is that I want to place a crossover (CV 1 in 9.25) between the two lines however the crossover is vertical which means it has a gauge of 1432.
The issue I am having is trying to tell BRT that;-
Can anyone provide some insight on this?
