Hello!
There is a way to use regression points of rails to regress CL (the offset value). But the horizontal slew annotation is not affected by the option. Did I miss something or is there an enhancement needed?
I tried as you say. Included, created new long profile. But still not work properly...
Can you try on your station is it work properly?
A. K. Mateev
P.S. I'm sorry by mistake i tagged your post as abuse :(
(BRT V08.11.07.685, on MS, SS 2)
Hi Aleksandar,
I did some few tests on version 08.11.07.685. I have created some COGO points (straight element), then added to an alignment as regression points, then set the offset to 2m.
So try to use SIngle Element Regression and let see if it is correct.I have to do some more testing and I will probably fill a defect with data attached. You can even send me your alg if you wish.
Hello, JPLN I haven't problems with the regression result. I already have an alignment. My alignment is created by other points. But I add some points to horizontal regression points from our survey data (of rails, of course) just to annotate the longitudinal profile - horizontal slew and vertical slew. It's logical if I put some offset on horizontal regression data to have a corresponding result in the annotating also. (after all I need Existing CL to Project CL slew data) --- I try to create new element by the regression points, and created longitudinal profile, but the problem appeared again. And it seems the problem is not that i haven't created the element from the points that i want to annotate as slew data. Regards
TEST.dgnhttps://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/5921/for-JPLN.alg
Answer Verified By: Aleksandar
