Hi all
Hoping someone could help with creating a cant report.
I have an existing center line from which I want to create an existing cant report.
I want the report to start at 100m, end at 247m and display the existing cant in 3m intervals.
The problem is that when I select Geometry Reports select a 3m interval, with starting and ending stations of 100 & 247 and produce the report, the report starts from 100m, then 102m, then 105m and every 3m after that. I want the 3m interval to start from 100m not from 102m. Does anyone know why BRT produces the report so that it includes 102m?
I have solved the problem by using a 1m interval and than deleting what I don’t need but I am just curious as to why the report starts the 3m interval from 102m instead of 100m.
I have attached a screen shot of the report.
Try changing Tools>Locks>Station.
My guess is that the program uses the station from the start 0+00.000, and imaginary run the report from it. And when you want to start from 1+00.000 it already have a next point at 1+02.000 because its 34x3 from the start.
(BRT V08.11.07.685, on MS, SS 2)
Answer Verified By: Stewart Souten
