This is a Power Rail Overhead Line related question.
In the overheadline structure templates I added some dimensions to the structure. These dimensions show in the final sheet model after creating a cross section. However all dimensions are dropped to lines and text.
Is it possible to NOT drop these dimensions. Our final drawings need to contain correct dimensions and not dropped ones.
T.i.a.
Erik van Zuidam OLE Engineer/Designer
