Hello!
I have this situation:
As you can see, there is 2 roadways, separated by 150m empty space.
When I try to create the surfaces, the "Add Exterior boundary" makes boundary around the first roadway corridor... and the second roadway corridor stay out of it.
In case I turn off this option there are many extra lines that must be cleared. When i set maximum length in surface parameters, to clear them, there are still extra triangles in inner side of the surface, with lower length than "Maximum length" parameter i can set.
I do not want to turn on the "New surface for each corridor" because in the process of work the roadway corridors will be about 9-10, and will create about 60-70 surfaces ...
My question: Is there a way to make roadway to create surfaces from different roadway corridors (that are with same name in the template) in same surface?
(BRT V08.11.07.685, on MS, SS 2)
