Hi all, I have problem with make XML report of alignment in track transition curve area.
When I use Tools-Tracking- Horizontal Alignments directly track on alignment geometry, I can see there is cant with varies values. But when I try to make xml report- geometry, I have tried different cant report type, it either "jump over" the track transition curve area, or gives value "0" which is wrong.
Can anyone please help with?
regards
Shi
Try this:
(BRT V08.11.07.685, on MS, SS 2)
Thanks Aleksandar,
But I tried again it still does not work for clothoid part.
Is it possible that you could have a look at the alg. file I m working with? If so, can you please leave your e-mail address?
Thanks in advance!
SHI
