Hi all
I was hoping someone could help.
I have designed a center line and stationed it. To ensure that i stationed it correctly i used the tracking option to confirm that the stationing was correct.
I than designed the vertical alignment.
The problem is that when i use the tracking command on the vertical alignment, the vertical elements starts from 0m - But they should be the same ???
Can anyone explain why the stationing of my design horizontal alignment would be correct but the stationing for the vertical is incorrect?
I am using Power Rail Version 08.11.07.685.
Thank You.
Stu
I guess in place were you add starting station of your horizontal alignment, you must chose synchronize starting stations:
(BRT V08.11.07.685, on MS, SS 2)
