Hello again!
From time to time I wonder how better is to use turnouts.
Is there some practical reason that the horizontal alignment geometry (created by connection editor) to be placed separated from adjacent geometry?
This is very unpractical, every time I add turnout I need to create new horizontal alignment by selecting elements from the old (adjacent) HA and the new HA from the turnout (there is no option as I know, to be created merged). Because I need my starting point in longitudinal profile to be the beginning of the turnout (I need them as single alignment).
There isn't option that allows to annotate turnouts in curvature tab (profile annotation). Current option for annotate in profile does not give enough freedom.
Can you list the pros and cons of this feature?
The cons that I listed are enough to make me abandon this function.
Can you describe how you use this function, and for which purposes ( plan annotation profile annotating, alignment design, PROL etc., )
Hi, Richard! Thank you for your reply! If I have existing alignment. Very complex one, and I want just to add some turnouts on both ends. The Connection Editor creates new alignment for every turnout that I want to add to that existing alignment. Then to have all in one ( because I want to create longitudinal profile through the turnouts as well) I must recreate all horizontal and vertical geometry in some third alignment (or fourth if I want turnouts on both ends). --- As I understand from your post, if I want to create new track in some Station that departs from the main track, I must create it in Turnout Connection Editor? --- Is there any solution that can allow me to create longitudinal profile that instead to stop in .1 on turnout, to continue trough the other alignment ? --- Regards, A.M.
(BRT V08.11.07.685, on MS, SS 2)
Unknown said:If I have existing alignment. Very complex one, and I want just to add some turnouts on both ends. The Connection Editor creates new alignment for every turnout that I want to add to that existing alignment. Then to have all in one ( because I want to create longitudinal profile through the turnouts as well) I must recreate all horizontal and vertical geometry in some third alignment (or fourth if I want turnouts on both ends).
