In MX Rail when you float a straight by point or bearing, you have the option to specify a transition length.
Likewise when you free in a straight you can specify transition lengths on both sides.
However in BRT when you float / free a straight I can't see any option to add a transition length. Why not? Is there any workaround?
I'm using BRT version 08.11.07.566.
Neville du Plessis
Rail Design
Hello MX Team (I have been also using MX for many years),
Inroads, so Rail Track, has a totally different way of managing alignment than MX. Then we can feel sometime a bit lost even disappointed. But on the other hand we have more freedom than MX gives.
If there is a transition already attached to the arc then you can add a float line by a point asking to connect the ARC not the transition. Then you are able to move the point and see the dynamic link including the transition.
Rail Track allows to create arcs with transitions even there is no element after the transition. MX does not allow this.
So in Rail Track the best is to create the transition first. When you place the arc you may know you will continue the alignment and that a transition is required.
But there is a way to add the transition if it is not already there. Sorry, It is not smart but it gives the result.
The workflow is using the Add Fixed element" command:
Answer Verified By: Bernard Jones
Here is again it is a difference between MX and Rail Track. In MX you edit links whereas in Rail Track you strictly edit elements.
And MX has elements and links, Rail Track only knows about elements: connected, colinear or not.
In this case the way is not to edit elements but replace the connection. Very similar than MX replace link command, except that using Rail Track you can keep both. An alignment in Rail Track is just a list of elements, only the user maintains the logical in this list. A lot of freedom but with some additional management.
