All of a sudden the horizontal curvature diagram started displaying points like this:
If i start a project where the .alg and cogo-import was made before the weird error there is no problem drawing a new curvature from them.
Which have me believe there is something going on with the import of the points.
I have tried uninstalling and reinstalling Power Rail Track. I have cleaned the registry. deleted files form appdata, no matter what i do the problem persists.
Please I hope someone can help with this.
The points by themselves are ok. This is the same curve from an .alg saved previous of the error appearing.
Using the same settings for horizontal curve diagram the curve displays correctly.
This have me believe something has happened with the way PRT imports the cogo points?
The weird thing is as you can see from the top picture the northing and easting of the points is correct. So it must be something else.
Im drawing a blank.
oh and the radii of this particular curve is 400m ish
Consultant Rail
REJLERS Infra 5161 Södra Storgatan 11, 252 23 Helsingborg Fakturaadress: FE 417, 838 80 Frösön Mobil: 072-050 46 63 Tel: 0771-78 00 00 Simon.EdlundStephensen@rejlers.se www.rejlers.se
I have found what happens, but not why it happens.
PRT states it has succesfully imported the points. And as you can see there is decimals to the northing, easting and elevation.
But the resulting import looks like this:
Decimals lost and all values rounded down.
Neville du Plessis
Rail Design
Answer Verified By: Simon Stephensen
