In template Point T2-U2 is controled from T2-D2 by slope and project to surface up:
Point T2-D2 is controled by ditch, and this point moves down and left.
Result:
But instead T2-U2 to chase T2-D2, the point acts as the parent point stayed at the same location in template. In this example only when solution for project to surface is not active:
This appeared many times in "healthy" conditions. And mostly from Slope and Project To Surface controls.
Is there some restrictions to not use Point Control of points that is used for Constrains of other points, or this is some kind of bug ?
Answer Verified By: Aleksandar
