Hello!
My question is about the Surface Type option. This option is used for determination of quantities.
In my roadway design I have ~150 surfaces. For every one I must change the preferences to Design. Is there an option that I can set for every surface in template to be created straight as Design Ignore, and so on?
As I can see the common surface is Design, all others are Ignore. But this common surface I can't use for quantities because include all fills. How can I set the common surface to be created straight as Ignore?
A.M.
(BRT V08.11.07.685, on MS, SS 2)
