Hello!
I have the following problem.
I have 2 turnout on some mainline. They are connected by second line. The mainline is parent and the second one is recognized to be on branch directions.
All OK!
I use Connection editor to change the station on one of the turnouts. The station changes, the second alignment is changed too. The turnouts are OK. Saved the Geometry Project.
After 2-3 hours the program crashes. I have opened Geometry Project and the second alignment is OK. But the turnout has stayed on the old place?!
This occurred many times. And I'm not sure that every time was caused by crash of the BRT.
Why when I save the geometry the turnout is not saved with on it instantly.
Screenshot:
Answer Verified By: Aleksandar
(BRT V08.11.07.685, on MS, SS 2)
