Hello everyone,
I set up stationing by means of tool ‘geometry->view geometry->stationing, so that the kilometer 12+000 (drawing 1) was at the end of the green Line. Afterwards, I extend or shorten route before the place where I set the stationing. For example, I extend radius (drawing 2). The ending of the green line changes kilometer. Is it possible to attach stationing, so that it could have a constant kilometer in a particular point (in my example that’s the end of a green line), even if the changes in geometry are made before this kilometer?
Geometry before changes, kilometer 12+000 is attached to the end of the green line.
Geometry after the change of radius (route is shortened).
Try to use, Geometry>Horizontal Curve Set>Stationing/New:
Use ''By Norting/Easting",set your coordinates of the 12+000.00 point and on Ahead Station must use some prefix, like this:
Good luck!
(BRT V08.11.07.685, on MS, SS 2)
