Using either Microstation V8i or AECOsim Building Designer V8i in conjunction with Bently ProjectWise. I am trying to create a 2D 'extraction' from a 3D model (I understand what a Clip Volume is and this is not what I am after so, please do not say to clip volume!) I have a 3D model of a London Underground tube station and I would like to produce a 2D drawing just like what is shown below. This is essentially a slice of the 3D building .Normally you would not be able to see whats inside unless you turn off the levels. I want to keep all levels on and cut through so it removes the front and back walls and only leaves the transverse walls and the ceilings/floors. The slice here is quite thick so you can just see the staircase.
This is exactly what I want to be able to do but, I dont know how. Could anyone show me a step by step way of producing this 'extraction' from a 3D model please.
If you need more info please let me know.
Matthew Edwards
