We can get the Track Centers via Pro Rail Extension, but dont know how to put in Profile (Evaluation > Profile).
You can import the existing alignment as regression points in the proposed. Set active your proposed alignment, use Add Horizontal Regression Points, check the "Horizontal Alignment Cardinal points": http://prntscr.com/atmf1g Then use Add Vertical Regression points as you wish (from the already imported horizontal points, or from the existing alignment cardinal points) --- You can use this regression points to annotate Horizontal slew and Vertical Slew annotations in Annotate Profile. http://prntscr.com/atmgzb
(BRT V08.11.07.685, on MS, SS 2)
Answer Verified By: Naveen Verma
