Hello all
I am in the process of creating some specific turnouts for use on a new project that specified the use of 1600mm broad gauge. All turnout definitions have been defined in a new turnout library and are all verified. I am happy with them
My issue comes from when I try to display them in plan.
When I use Geometry - Turnouts - Display Turnouts - I can see the turnout triangle and new rails defined as shown in the attachment (disregard IP in white - this is a separate issue!), but the locations of the Nose and IP are incorrect.
I'd like to know where in the software are these locations and the elements displayed at these locations are defined? As far as I can see, they are not cells in the active library. They are being brought in using the defined plan symbology for "Rail New" as shown in the S&C Nose and Crossing Object column. They are not affected by a change in the global scale factor either.
Would appreciate any help
Attached below is
- image of display turnout window
- image of turnout graphic I have the issue with
- turnout library extract of T/O used in this case.
Answer Verified By: Alastair Hume
