Hi All,
I am trying to generate profiles using PPG. Profiles are 500m sections and and H to V exag is 5. Surface is a little bit tricky with many steep changes and profile elevation shifts does not work even i go for left major tick spacing 1 it says it will not fit in. Top clearance is 0 and bottom is 20.
I rather not increase profile height, it is my last resort. Any suggestions about that would be great.
One other thing that would work for me is to have profiles generated following the alignment elevation, is that possible?
Thanks in advance
(BRT V08.11.07.685, on MS, SS 2)
