How do I show my Horizontal regression points on my design?I did a conversion from two rails into one imaginary Track Centre line. Using check horizontal Integrity, both H and V are showing in order along the new Track Centre Line. Then I apply / use button "ADD Horizontal Regression Point" (button number 3 from Left), picked the Centre Line, left click to accept, then Apply and close the menu.Next I go to button "View Horizontal Regression Point" (button no. 5 from the left) --> hit apply, and NOTHING shown on my Screen ???
(BRT V08.11.07.685, on MS, SS 2)
Hi Susanto
When creating your Centreline using Geometry/Horizontal Regression/Convert Rails to Centreline, make sure you tick the radio button that says "Add to Horizontal Regression Buffer Only". This will create new a Horizontal, Vertical and Cant Alignment (if you tick all those options) but will NOT add the elements from that Centreline to your Horizontal Alignment. Then go to Geometry/Horizontal Regression/View Regression Points, specify your settings for displaying the points and make sure that you tick the boxes for at least "Normal Symbol" as this is the default for regression points styles.
Answer Verified By: Susanto Tjokro
