I have got the following problem to consider: is it possible to replace the symbol of grade in the annotation of the profile (annotate profile), in the selection “Grade and Distance”?
Currently the line looks as follows:
I would like to make it like that:
Instead of circles I’d like to draw vertical lines.
Had a quick look at this. The only thing I can manage to work is if you set the Percent of Frame Used by Diagram to 10% and see if you can make the circles small enough to not bother you.
My only other advise is to see if you can play around with the frame properties to see if you can get this to work.
